monkeystealer
Thread starter- Joined
- May 16, 2006
- 15
Hi chaps,
Several threads asking about switching to remotes, but not a lot of info about converting a remoted (is that a word) outboard to run off a tiller.
The motor: Mariner 15hp, serial:09685881 (Belgian).
Currently has linkage set up for remotes, I guess most of this will need to be removed). It's got a tiller fitted, but no throttle cables, and more importantly no obvious way of connecting any cables to the throttle.
I've found a schematic on the web http://www.ishopmarine.com/ishop/js...&isForSupStore=false&cCatFilter=&eCatSupFldr=
of the parts I need, but I'm still not sure that I've got it all worked out. I figure that I need parts:
3,4,5 and 6 to change gear, and part 1 to run the throttle cables to.
Where I'm stuck is figuring out where part 1 attaches to the outboard and how the cables are routed from the tiller to part1, then onto the throttle.
Anyone got a photo?
I'm off now to clean all the dirt off the engine - it really shows up badly under the flash.
Anyone got a photo?
