Once again, I have a '92 70 hp evinrude. Bought the boat in April '07, it did not have a theromstat in it. From April 'til July the motor went down hill. I pulled it apart and found pistons and cylinder walls trashed. I have since rebuilt the powerhead, soaked and rebuilt the carbs, installed new reed valves and a thermostat and replaced the water pump. Took it out Sunday and at idle the temp. is 160 degrees. It got up on plane real quick but the temp went to 220. I have run the boat without the thermostat and it ran fine. This is the first time I've run it with a thermostat.
I'm starting to think that I'm getting closer to finding the reason why this motor was on it's way out when I bought it.
So some direction would be very cool.
Thanks,
Wayne
Thanks,
Wayne
