Johnson 40 HP tilt trim problem
mehughes
The tilt trim on my Johnson 40 Hp will not go up or down.Even when you try to manually push it down it will not move. I can't hear anything when I push the up or down trim button.
tashasdaddy
Re: Johnson 40 HP tilt trim problem
will the motor turn over and start? check inline fuses on the motor. what year or model # 40 hp.
mehughes
yes the motor will crank and run. It is around a 2002 model
mehughes
yes the motor will crank and run. It I believe is a 2002 year model.
tashasdaddy
you have a private message. clik private message at top right of this page.
