Ensure your boat is in good shape
fixb52s
These guys were lucky they made it. They are also lucky their boat was recovered. It started with a broken steering cable, and ended up with the boat capsized.​
Is it me, or does the transom look a little worse for the wear??​
This is a great example of why you need to have the life vest on at all times.
tashasdaddy
Re: Ensure your boat is in good shape
a case of poor maintenance, and not checking the weather. they were extremely lucky.
NelsonQ
That must've been one scary (and long) swim knowing they were chumming the waters behind them.
They were extremely lucky for sure.
I wonder it they had steered the motor manually. whether they could have avoided capsizing. Although 5' waves are a challenge for an 18 footer, that boat is generally pretty seaworthy.
It would have taken a good skipper and good coordination with the "steerer" to pull it off.
captquest
WOW .
1) The boat looks a bit small for venturing much further west of Egmont, it's condition looks questionable also.
2) They should have checked the weather and stayed in the Ft. DeSoto Park area, would have been much calmer.
3) Where are the life vests?
Here are some interesting facts I did not know. Am I reading this right?
There are more registered boats in Florida than California?
But there are more accidents in California?
http://www.floridaconservation.org/law/boating/2007stats/review.pdf
dave11
I launch from Ft Desoto a lot. I remember the forecast for that day. 15 to 20 MPH winds. I stayed home for a couple of days because of the weather.
BSIGS
Check the weather before heading out ...
Good day. :)
reelfishin
It looks like a jack plate or something behind the motor. The transom looks like it may have been painted with bottom coat which is wearing off.
Either way, too little boat for the conditions and poor maintenance. A lesson learned the hard way.
