LakeTexomaBoater
- Sep 6, 2008
- 17
Hello all, I posted before about this engine and finally got the book on it. Im having a problem though, I tried to check to make sure the manual release valve for the trim was tight.. the book says its located on the bracket, yet I see no valve, plug, anything that appears to be "turnable". I do however see a knob on the side of the main trim cylinder, but it turns both ways and never tightens. Its not leaking around there at all, but when I turn it, fluid does pour out.
Another problem, located under my lower unit, there are two bolts that are perfectly vertical. On each side of those two bolts are two small holes, oil is dripping out of those two holes, would that be from a bad oil sealer or any ideas?
Oh, and one more thing.. When I have the motor raised up, it seems that each time I take it out, with that angle, fuel has leaked out and has pooled in the covers in front of the carbs. I know that can't be good. Any ideas there?
I know, lots of questions, I did buy a book, but the troubleshooting in that book really does not answer anything I need.
Thanks in advance.
Thanks in advance.
