Hi guys,
I'm new to this forum as a member, but have been here often to read up. I must say I've learnt alot. Last year I bought a 91 Invader 18' bowrider with the 3.0L mercruiser alpha 1 drive.
From this site, I learned how to change my own bellows this spring. Now I've just winterized it myself for the first time. I did take a few tips from a couple of guys at work who use this on their I/O's.
I stabilized the fuel, added an octane booster, changed the fuel/water seperator (which I installed as well). With muffs on, I ran the boat at 1500 rpm for about 10 or 12 minutes. I was told to do this to open the T-stat. I then had a pail with a hose plumbed in the bottom, installed muffs again, filled it with 4 gallons of -50C antifreeze with corrosion inhibitors. Placed the pail on the swim platform, then started the boat and when the antifreeze was almost gone, I then fogged it until stall. Then I pulled the plugs and sprayed some fog oil into the cylinders.
I've read on this forum that this way probably won't work and may still crack a block.
Has anyone else tried it this way? I believe 4 gallons was enough since the discharge was pink for about 2 minutes. I just wondered if I should have used say 6 gallons.
My next step was to remove the outdrive and put it in the basement for the winter so I can change the water pump. I'm going to get an aluminum plate made to the gasket template with a hole for the shifter to stick out. This way nothing will get into the opening.
All your opinions are appreciated,
Thank you,
Thank you,
