stormtracker
Thread starter- Joined
- Sep 16, 2008
- 10
Hi all.
I just got a 84 Glastron CVX16 with a 1989 Johnson 88 SPL somewhat cheap.
It seems to run ok but after I shut it off I noticed oil leaking from the prop area.
I assume it's the prop shaft oil seal, and have found it online. Is this easy to replace? I have rebuilt car motors, but never messed with an outboard before. Do I need special tools to pull the seals? Or, due to the age, should I just pull the entire lower unit, and do it all with a seal kit, and water pump kit, etc., and is that a DIY, or a big money boat shop job.
This is a project boat as I also need to replace a rotted floor. but wanted to get a little use out of it first.
Any thoughts appreciated.
Thanks
Stormtracker
Thanks
Stormtracker
