Ok I am only about 3 months into this motor and I remember the guy telling me when he gave it to me that it had a new head gasket. (cylinder head gasket). Well now I see that sometime in the past one of the spark plug holes had been stripped out and they had added liquid metal and actually drilled it out bigger, then inserted some kind of threads that fit a spark plug and then sealed it up. They did a good job of making it look good, but those circluar thread reduction piece they put in there came loose and is actually stuck on the thread of my spark plug. Long story short, I am getting a new cylinder head. My question is do you always have to change the gasket when you do this, or only if it is bad. I know it is fairly new. Also, I will have to switch over the thermostat, is there any gaskets or seals in there that will have to be changed due to just removing and replacing?
thanks guys
thanks guys
