Would this work?
zach103
sitting in the hot tub tonight i was wondering if a light from a hot tub would work as an underwater light for a boat.. obviously it would need some modifications . but would it work or too much pressure from the water??
achris
More fish than mountain goat
Re: Would this work?
How far underwater are you intending to take the light?... Pressure increases at about 1 atmosphere (14.7psi) per 33 feet of water...
Chris........
ebry710
Ensign
How far underwater are you intending to take the light?... Pressure increases at about 1 atmosphere (14.7psi) per 33 feet of water... Chris........
Good point. Anyway, a hot tub light is probably not low voltage, just sealed. There are 12 volts light you can get that are design for what you want. What were you planning?
zach103
wasn't planning anything just an idea that came to mind. my boat only sits 2ft in the water. if that. i just think it looks cool with one of the lights. so i thouhgt i could try it . just not sure how i could get it in there considering my floor is completly glassed down.
zach103
how would it look if its half above have under? i have two holes on either side of my ob. two at the bottom of this gray part.
they are usually around the water line . could it work ther. then i wouldnt be drilling any holes that could jepordize the inside of the boat
achris
I like those!!!
As long as you mounted them so nothing protruded below the bottom of the hull, they shouldn't cause any problems....
Just be aware that a 50W lamp is going to pull some serious current.. about 4 1/2 amps... Don't leave it on overnight!!!
Chris.....
mthieme
Check this out...
http://www.wakemagic.com/
You'll be the coolest boat on the lake.
Google underwater marine lights and you'll get 1/4 million hits.
Better than leaving a hole in your hot tub.:)
zach103
google is where i found these lol. google shopping that is.. i dont want to spend a lot thats why i came to these.. i trailer the boat. so when im out at night i would see that its on . . so you guys think that would work on the back. but as long as its not protruding on the bottom. it will be right next to the trim for my ob
zach103
im trying to find a cheap solution to those td
zach103
so should i take the plunge and be the first to try this out????
