exhaust manifolds / risers
Wahoo Cruiser
We have a leak at the riser gasket on our 1983 5000 sunexpress 228 motor, But I have a few questions,
How often do exhaust manifolds need to be changed(these are OE)?
Should we change them out ho matter what?
External inspection stud and hardware rusted as usual, I want to remove risers and inspect manifolds visually first before changing parts.
Should we just change riser gaskets and stud hardware?
What should we look for inside?
Can manifolds be sand blasted internally? I was told yes...
Compression test is strong in all cylinders, 1 is slightly lower as usual. Engine temp runs 150-160 @ times when run hard gets to 180 temporarilycomes right down. No water in oil
Don S
Re: exhaust manifolds / risers
When you remove the riser, make sure the areas in red in the pic below are metal and not black carbon. If it's not metal any more, replace the manifolds and risers.
IF they are plugged up with rust, replace them, DO NOT clean them. The rust comes from inside the manifolds and indicates they are failing. again, replace them.
Saltwater boats get manifolds replaced about every 8 to 10 years.
You may not have center rise manifolds on your engine, but the gasket surface and procedure is the same.
sparky71
Something to add; If the surfaces don s spoke about are ok where can we get the risers for thes older style(risers at rear of manifolds) manifolds?
All of the ones I see are for center rise. Are they the same?
achris
More fish than mountain goat
Still available from Merc (part# -76351A04) ...Not the same as centre rise
Try www.mercruiserparts.com
Chris..............
sparky71
Thanks chris that looks identical to mine.What is the difference between 3" and 4", is it the diameter of the outlet before it goes down into the "y"?
achris
Yes....
3" and 4" is only relevant to the centre riser elbows....
Chris..........
Don S
Sparky, if you have questions, start a new thread of your own, let's not hijack WC's thread and turn it into yours.
sparky71
Sorry for the confusion Don, but this is actually my boat the OP is talking about. We went halfs on it,and are going to be doing this together.Just trying to add to his question to get as much info as we can.Again sorry for the confusion.
Dan
smithrock
Don, in the pic, which ones are the water inlets and which are exhaust outlets?
bolo78910
the area mark with red are the water passages, the big hole in the middle is for the exhaust only.
smithrock
Okay, so could a gasket leak from the water passages into the exhaust port cause water to enter the engine and oil? I have water coming out my #1 cylinder.
achris
Did you read the rest of this thread? Don't hi-jack other people's threads!... Start your own ....
smithrock
Sorry! I do have one regarding my problem! I saw the pic that Don posted and it related to my problem so I thought i would ask. Just trying to solve my problem, didn't intend to hi-jack anothers' thread!
