Moody Blue
Thread starter- Joined
- May 24, 2004
- 3,136
Have a 1971 Merc 800 80hp that will soon be installed on a refurbished 1970 Wilker fiberglass deep V hull.
The motor has two transom clamps (like you would see on smaller tiller motors) and provision for four bolts. In addition, I have added PTT to the motor, and the PTT brackets have their own mounting holes (4 in total). The PTT brackets bolt directly to the motor midsection. Because of the position of the motor on the transom I can not use the top two bolting points on the motor.
So I have the ability to install two lower bolts on the motor and 4 bolts on the PTT, two lower and two upper. Do I really need the two transom clamps? How can I remove them if I decide to do so?
