How to change belts on 5.8l V8 OMC?
dejavu
Hello,
I have a 1993 Four Winns Horizon with a 5.8l V8 OMC that squeeks and squeels at start up and on acceleration. The noise goes away once the boat gets going. I've read to change the belts and sand down the pulleys. How do you change the belts? Any pointers? I have direct access to the two belts in front of the engine so it looks like a piece of cake to change but don't know what to loosen to take the belts off. thanks,
wvwarlock
Re: How to change belts on 5.8l V8 OMC?
there should be 2 bolts (one on top one on bottom) of alternator loosen those to release belt tension.
Ayuh,....
I hate to say it,...
But,....
If you're asking That question,.... You need a Mehanic....
wvwarlock
if you have ever changed a belt on a car it is the exact same thing. it is easy to do so don't let others discourage you.
dejavu
Squeels no more
Squeels no more
Thanks for the diagram. It took 10 minutes to change. I knew it would be easy, just didn't know what to loosen.
wvwarlock
just glad to be of assistance. life is easier when we all work together.
