How can oil get into the heat exchanger/coolant? I just replaced the gaskets on a Crusader CH220 1983 chevy 305 cid. There is gunk in the coolant/heat exchanger that looks like oil. Could it be the heads weren't torqued right or in the wrong order? They were serviced.... I have a feeling the mechanic did;t get a good seal. Could it be the intake manifold that's not sealed? What are the possible damages that can be caused by oil gettinginto coolant? Also, what are the problem with great compression on newly serviced heads, and poor cylinders/rings etc? Lot's 'O Questions.... I know...
