glrichards
Thread starter- Joined
- Jan 17, 2006
- 44
Well I got a new pontoon and a new set of problems
It has a 115 4 stroke merc that only turns 3200 rpms with 8 people on board 3400 with 2 on board. The prop is 13.5X15 the toon is 24ft 8ft wide and with a full tank of fuel and gear is about 2600 lbs. The Dealer says that is the prop that they put on all the new toons and haven't had many problems but will work with me to get this resolved. He has contacted Mercury and is sending a new prop that they recomend.
The other problem is tounge weight 140 lbs. the toon full of fuel on the trailer weigh 3500 lbs
I moved it forward 5 inches and only picked up 40 lbs to 180 I can move it 4 more inches or should I move the axels to the rear to pick up more tounge weight.
