orthoguy
- Aug 31, 2008
- 52
I'm sorry if this answer was posted elsewhere, but I have been searching the forums and couldn't find my specific answer...so here it goes:
I recently bought a 1974 SeaRay with a straight 6 Mercruiser 165 HP, the guy said it started idling rough last time he had it out.
OK, I get the boat home and it was hard to start without applying 1/2 to 3/4 throttle. I got it running but could not return it to neutral without it dying. It would only stay running above 1500 RPM's I ran some seafoam through it with no change. I replaced the plugs...which the old ones looked good. The spark plug wires are newer and it looks like there is a new distributor cap on it. After replacing the plugs and it still won't idle correctly without dying, I decided to take off the carb and rebuild it. As I was starting to disassemble the linkage and fuel lines, I noticed that one of the idle mixture screws looked like it was screwed in too far, so I tried screwing it in to see where it was set at and I only could turn it in 1/4 of a turn....so, I set both of the idle mixture screws out 1 1/2 turns reassembled the fuel lines and tried to fire it up....It started IN NEUTRAL with the tap of the key! I ran it until it was warm and it was smooth as silk, never stumbled once.
I take it on her maiden voyage today and after idiling out to the lake for 20 minutes, it is running nice and smooth! I start to take off and now it stumbled at 2000 RPM and above, cuts out until I back off the throttle then runs smooth again. I slowly advance the throttle and get it up to 2000 RPM and it ran fine...try and throttle beyond 2000 RPM and it dies altogether...Now I have the complete opposite problem, now it idles but won't run above idle. OK, so I run it around the lake for about 45 minutes at 1500-2000 RPM the warmer the engine is getting the more it starts running rough and dropping in RPM's that it will run at and finally dies at ANY RPM! I have to re-start it several times to get back to the boat launch never getting above 800 RPM's and never could keep it running for more than 3 seconds finally dying 200FT from the ramp and now will not start at all and the engine is hot and the temp gauge is just shy of leaving the Green range and entering Red...so I have to paddle this heavy boat the rest of the way in!
I have read about electrical issues and carb issues both having similar conditions as mine, but have no clue where to start. I see that the carb is getting gas, but I didn't get it taken apart to inspect the float and so forth. Why would it all of a sudden run fine after I fixed the idle, now die out on me? Is it a temperature issue? Fuel? Points? Carb?
Help....I appreciate it!
Mike
Mike
