Boatman296
Thread starter- Joined
- Aug 9, 2008
- 5
Sooo I bought a $1,500 "fixer upper" 18' Baja with a 4.3 a month ago as a winter project. Two weeks later I noticed a very nice 21' 1995 Baja 208 with a 350 Mag at a local auction repo lot. As of 2 days ago, I now own two boats! My wife couldn't comprehend why I bought one when I already had the other. The reason why is because the 21 footer has captain call exhaust, very clean gel coat, good interior and we were able to use it yesterday instead of next May.
The boat fired right up after having set for a while. After richening up the carb a bit, it got on plane a faster. I would still like a bit more hole shot since I like to slalom. The boat has a SS 21 pitch prop and went 58-60 on the speedo at 4900-5000 rpm. I would like to stick with the current prop for the top end (plus it has a prop lock nut on it and the key didn't come with the boat). I have read that smart tabs really help with getting on plane. Those would probably be my first option. I have also read that Vortec heads flow a better on the 350's. I am not sure if this boat has a stock cam.
My questions--
Would Vortecs help with low end hp and torque or would they kill it? I assume a bit of performance will also be gained from the necessary aftermarket Vortec compatible intake upgrade.
Will in need to go up in carb size from stock if I use the Vortecs? It has the original Carter.
How good are the Carter's vs a marine Holley with vac secondaries?
Thanks in advance for your thoughts.
My questions--
