Need R&R MANUAL FOR 3.0 MERC STERNDRIVE
Bayliner195
Looking to install new impeller and install hour meter need to find a manual to help me do this any ideas here ..
2005 bayliner 195 classic 3.0 merc sterndrive,alpha 1 gen 2
Don S
Re: Need R&R MANUAL FOR 3.0 MERC STERNDRIVE
All you need to know is in the OEM service manual. Link is below so you can download it.
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/14/14cover.pdf
Section 2A will explain how to R&R the drive.
Section 3B will explain the water pump impeller.
The hour meter is simple, purple wire and ground off one of the instruments easiest to get to for power and ground.
Bayliner195
Also was wondering if u could point me in the direction of the gm service manual for the engine 3.0 l
thanks
