licketdsplit756
Thread starter- Joined
- Jun 15, 2007
- 318
j140txccm running this motor on muffs. after 2 to 3 min vro alarm sounds beep......beep...... beep i believe a constant alarm is overheating. i squeeze the bulb when off the engine. oil squirts out. at this time i have a 26 to 1 oil ratio in the tank for safety reasons. with the vro also hooked up.could it be the vro is not mixing correctly? causing alarm to sound? maybe the gas ? the motor is not getting enough to make proper oil to gas ratio 50 to1. im lost racking my brains out here. everyone knows at 52 yrs old those brain cells are important . please advise me what to do thank you . after warm up
she runs pretty good. still on muffs. but still alarm sounds. there is enough exaust smoke to see there is oil present in the gas.
