Water pump installation - 1992 200 HP Mercury
jdupree
I have 2 questions:
1. When replacing the water pump, should the base be replaced as well?
2. I have a Seloc manaul and it says to coat the impeller and housing with a water resistant grease. Should that be done?
achris
More fish than mountain goat
Re: Water pump installation - 1992 200 HP Mercury
You only need to replace the base if it's damaged or melted slightly.... I always put a very light smear of grease on the inside of the impeller housing... It makes the impeller easier to install and gives it a bit of protection on the first start before the water can get there..... Doesn't have to be water resistant, any grease will do....
Chris............
P.S. trash the solec and get a genuine manual... You'll thank me.... :D:D:D
