I have a 1975 115 Johnson Model # 115ETL75E only running on 3 cylinders I know this from pulling plug wires while running, number 3 makes no difference at idle or high idle. This motor has not been running for about 3 or 4 years, I have run at least 10 gal. of gas through it with seafoam added after I bought it. It has 120 to 125 lbs. compression on all 4 cylinders I have tried so far to switch plugs from good cylinder to #3 problem stays at #3 also tried switching coils problem stays at #3. Is it possible for the reed for this cylinder to be stuck shut causing this and if so how can I get it freed up with out tearing it down. I am going to try decarbing it tonight with seafoam if that don?t work any suggestions. I don?t have a manual yet for this motor I bought it on a bass boat to put it on my pontoon when I get it running right.
