johnnynegaunee
Thread starter- Joined
- Jul 24, 2007
- 69
You folks have provided me with answer you can't find in the manual, for that I say thanks. Well I got a few more.... I'm realitively new to I/O's. I have a '72 3.0L Merc.
When I first put the boat in the water I started her several times with the drive up and the R's at 1-2K before saying oops and lowering the drive. That said, recently I find the outdrive u-joint bellows leaks greatly when its up and in the water, but no leaks with the drive down. I'm now trying to replace it. I see scoring on the inside of the rubber. Is this from running the drive in the raised position? Or is there another problem to correct? In the manual it looks like I need to disconnect the shift cable at both cable ends, is this correct? And why?
