Hi folks,
I recently got a hold of a 74 Johnson 15hp model #15R74S. I bought it knowing it didn't run very well but figured I could fix it and have a good motor for cheap. Now I'm wondering if I made a big mistake.
Here is what it's doing, it's hard to start and when it finally does it will idle OK but not real good. At full throttle in forward gear it won't even blow water out of a 55 gal. barrel. When I come out of full throttle it will usually die and is hard to restart.
I went to a marine repair shop who has a pretty good reputation and he told me that my particular year model is basically junk. He suggested I get it running as best I could and get rid of it. He claims 74 thru 76 9.9s and 15s were S--t! "they took three years to get it right" is what he said. Anyone ever heard this? Agree or disagree? Anyway I would like to get it running. Here is what I know.......
1-New plugs
2-All new fuel lines
3-rebuilt fuel pump
4-carb removed disassembled and cleaned
5-by-passed fuel connectors
6-Ran from gas can eliminating tank problem
7-points cleaned and gapped (recently replaced)
8-coils were replaced before I got it
9-compression 118 and 120
10-timing ring moves freely
11-both plugs have spark
12-pumping fuel bulb doesn't help
13-rich/lean adjustment on carb only changes the way it idles
all this and no significant change, there was some change after rebuilding the fuel pump. One time during all this it woke up and blew water everywhere and then promptly died and when restarted it continued it's sluggish behavior.
Can anyone help me out? Or should I just take the shops advice and cut my losses? He also said he has never seen one in those years that ran real good.
Any input is welcome and appreciated. I usually get good help on these kind of forums and I suppose this will be no exception.
Thanks.
1-New plugs
3-rebuilt fuel pump
Thanks.
