stu man do
Thread starter- Joined
- Aug 2, 2008
- 29
I have twin 2001 Volvo Penta V-6's 4.3 GI PEFS. One engine warms up to 175 degrees within a few minutes, the other never budged off of 100 degrees. I switched temperature sending units with no change. I then replaced the the thermostat. Slight change happened when I did this, at idle the temp. goes up to 130 degrees, but when increased to 2,000 rpm's it drops back down to 100 degrees. The stat I installed was 160 degrees. Anyone have this problem, and what else can I try? The guage does jump up a bit when I turn the key on, and now it moves to 130, so I am assuming it is not a bad guage.
