AguaSki
Thread starter- Joined
- Jul 4, 2005
- 545
I just had my boat in the shop for a carb rebuild. The carbs were almost completely clogged, and small black particles can be seen in the fuel sample. In addition to the carb rebuild, I am getting new fuel lines and a rebuilt fuel pump. The shop also recommended their fuel tank cleaning service, but I had to stop the bleeding on my final bill some place. Rather than have the shop do the tank cleaning I plan to do it myself to save some bucks. So, how is the best way to clean the tank? I estimate that I have about 14 gallons left in my 28 gallon tank. If I drain the old gas and install a fresh filter, is a tank cleaning really needed? I never had a water/fuel separating filter, but I plan to add one as part of the fuel system rebuild. If the fuel tank cleaning is really needed, I am looking for advice on the type of chemicals to use, and the process I should use.
The motor is a 1978 Johnson 140 hp.
