Hello forum,
I have a 1986 125 hp force. I just got done fighting the ignition system all summer & got this thing running good. I took it out for my first test run and it runs pretty good, but as I left the boat launch, it would not go into forward gear smoothly. It would just grind. I adjusted the cable all the way in and out and had no change. I disconnected the cable and manually shifted the shifting bracket with my hand as far as it would possibly move and it would maybe go into gear very briefly and pop back out and grind again. My guess is there must be some kind of drive dog inside the lower unit that is rounded off some. I dont think it is the gears because reverse stays in better (not quite right though.) I have not ripped into the lower unit yet but will very soon. The prior owner said he had to pop it into gear fast. Any ideas where I should start looking for this problem? Im sure one of you boat mechanics have been into a lower unit or two can give me some good advice!
Thanks
Thanks
