Birds and Gulls...
pbuzz3323
What has anyone used thats fairly effective in keeping the birds off the boat..Ive seen repel a bird and the spider wire thing..Anyone use them or something else?
puddle jumper
Re: Birds and Gulls...
I don't know how to keep them off your boat but some friends of mine were up in the Queen Charlotte's. They had a month of supplies for a camp job. They went into a store and when thay cam out every Crow/Eagle/Sea Gull had eaten all of there food out of the back of there truck. Man i laughed when i heard this.
pine island fred
Dont know your circumstances but what works for me is hanging ribbons of canvas or old beach umbrellers over my boats and vehicles. My problem is with egrets and herons, ribbons interfeer with there wing, works great. Might not work if you are dealing with smaller birds. regards FRED
ebry710
Ensign
My sister uses fishing line strung around mini posts and other structures. The birds don't seem to know what to with it, its cheap and you cannot see it from a distance.
At Bodega Bay, I have also seen little ss wires on top of fishing boats and the seagulls seem to stay away from them. They remind you of porcupine quills.
Lou C
I keep my old 88 Four Winns 200 Horizon on a mooring here in Long Island. The birds were crapping all over the cockpit cover and making a real mess out of it. So far I have had good luck hanging pennant flags (can get em at West Marine) strung from one front cleat, up to the VHF antenna (made a gadget to pass the flags thru and hold them high enough) and then I run it back to a rear cleat on the same side. So the string of flags goes from the port front cleat, to the VHF which is on the starbord side and to the port rear cleat. The zig zag of the flags seems to make them not want to land on the mooring cover. Usually by now I'd have cleaned up a bunch of messes but so far so good. I got the idea from the fishing boats I see moored around here.
pbuzz3323
Thanks for the tips...Where on Long island? Im at cedar beach in mt sinai
bchboater
I had a Grady Tournament kept on a lift. They set up a nest inside the boat by flying up under the port storage compartment. It was an awful mess to clean up. Nothing worked until I got a cover. The pier is a problem too. I have strung the fishing line on both sides, and now they have mostly adapted and use it like runway markers, flying and landing lengthwise on the pier. My neighbor tried the pivoting owls on their pilings, saw they sit on the owls and poop on it. I might try the flags mentioned above.
fishmen111
Velcro a cat to the windshild...replace weekly.:D
gcboat
Had the same situation until someone told us to get one of those plastic owls. About 18 to 24" tall. Hung it from the rafters in the boat house and never had a problem after that. Worked like a charm!
arboldt
We've seen too many gulls sitting next to (and even on) those plastic owls, snakes, etc. We hook a wind sock that has lots of streamers onto a fish-hook swivel, then put that at the end of a wire, and one on opposite corners.
The trick is it cannot be fixed -- the entire thing has to swivel, sway, and swoop in the breeze, in addition to the flapping of the pennants. If something is always in the same place or not moving, gulls will soon get used to them.
A neighbor uses a tyvek loon on the same kind of setup. It swoops and soars, never in a predictable pattern.
The other approach is the very thin string or cable or heavy fishline strung back and forth. That seems to discourage them, but it's a PITA to put up and take down. From what I've seen, it's most successful on top of a canopy over a boat lift.
Phil G.
After a lot of scrubbing, and some internet research, I'm using 12 lb. monofiliment fish line zig zaged over my dock, and pontoon boat cover. So far, so good. True, it is a PITA to put in place and remove, but it beats the alternative.
