I've recently been told that the "proper trailer" for towing your boat is based on the size of your boat. No brainer there. Question I have, is this.....I have a 19' Starcraft Bowrider. I noticed that my transom does hang over my farthest rear rollers by about 1 to 1 1/2 feet. Is that an acceptable distance w/out causing undue stress to the transom? My engine weighs about 300 lbs.. I've towed this boat several times on this trailer (the one in the picture below) but, since mounting the motor, I haven't towed it yet. Does that short distance between the farthest rear rollers and transom really make a difference? I towed a 17' boat on this trailer before and the rollers actually went past the transom by a few inches, enuf to make me wonder if a roller ever fell off, would the stub rub into my hull. So, if any of you have opinions of the proper trailer size, please share them. I'm curious as to whether I should be looking for a longer trailer. I can't imagine it making a big difference, but if it does...it does. My boat is rated for a 175 hp and I'm only using an 85 hp. Thanks for all input.
Chris
Chris
