jtcarter
- Apr 26, 2008
- 226
I have a 1995 175 evinrude intruder. I've been told i can't convert to just a regular fuel pump by one mechanic and that i can by another. I have a fuel restriction or a weak fuel pump. I Did the vaccum test earlier this week. On the fuel line to pump test at WOT it showed at reading somewhere between 1 1/2 to 2 1/2 (erratic would jump up to almost third notch then fall back off). I say that because the spaces between the 0 and five are not equal, its four spaces.The tester read right at the first notch on the vaccum side of the tester at idle speed. It never got above four at wot. Which supposedly is good.
On the fuel pump to carb test the psi reading at wot was in between 5-7 most of the time. It was kinda erractic though. But if less than 3 psi then that is supposed to be bad.
Anyway i went out today, lean sneeze as usual. I got my air mixture screws out probably two turns past spec. I went to the primer bulb pumped primer and got the lean sneeze out of it. I have my primer bulb pointing straight up to ensure the check valve stays closed, doesn't matter. I tried to check the pickup tube for trash and apparently no one has ever took it out.It threads down in a female fitting that is secured at the top of the tank with a large nut. Anyway i can't get it off without the whole thing twisting. I could take the nutt off and hold it. But run the risk of stripping the threads and never being able to put the nut back on. I may try blowing it out with air.
As if that isn't enough i believe the new gearcase i just had rebuilt is leaking water into it. I think i might have already screwed up my brand new gear set i just had put in. Another month setting around his shop unitl he finally gets to it. This fishing season has been a bummer. I can't even concentrate on fishing for thinking about how to fix my lemonrude. Next year its mercury pro xs for me please.
Something i forgot to mention. When i was priming getting the lean sneeze out. The primer would click after i started pumping the primer bulb. Something is causing it to lose prime . Sometimes you have to set with it and repeatedly prime it. But after you do the sneeze goes away. I know its a restriction but is it weak pump or fuel pickup tube? Needle vavles in all carbs close when you pump bulb no gas in carb throats. No anti siphon valve at tank either.
