An update on my engine.
I took my boat back to the mechanic that performed a tune-up and carb job back in March to have him make sure everything he did was fine. He checked the timing, link-n-sync, and all and said everything is great but he raised the idle up a bit.
The problem I have been having with my boat was that it would not idle but ran good at high rpm. Well, I finally got the boat out and found that he set the idle at 1100, out of gear, in the water. In gear, it runs at around 900. Lower it and the motor stalls. So that is all he did.
Is this idle too high? Will it damage my gears?
I plan on rebuilding my carbs later on this year but would like to use the boat until then. I don't know what this guy did, but the boat never ran well. He even tried to tell me my choke and throttle linkages were switched and was going to switch them back. I told him not to because they were correct as per the manual. But he insisted that they were wrong. So I don't have a lot of confidence that he went out of his way to perform a good job on my engine. Probably just slapped in a new carb kit and adjusted the linkage.
On a funny note, when I took the boat out, it ran okay, although hesitant to when throwing the throttle open. Did some fishing running from spot to spot across the lake. Then after about three 10-15 minute runs, the engine wouldn't start. I forgot to open the tank vent. The bulb was sucked flat and the tank partially collapsed. I think my fuel pump works well - haha
Thanks to all that have helped so far in my endeaver. I occasionally see persons out there asking for help and when they don't get the answer they want, they get mad. That's too bad for them.
Thanks again for your help so far and I know I will be bugging you all soon enough.
