Best RPM for Maximum MPG?
luckyinkentucky
What is the best RPM range for maximum miles per gallon?
I have an Evinrude 200 Vindicator V-6. Max RPM at WOT is 5500 RPMs. What would be the best rpm to maximize my fuel efficiency?
jevery
Re: Best RPM for Maximum MPG?
MPG should peak around 3000-3300 RPM and start to fall rapidly above 4000 RPM
Rancherlee
Get on plain then back the thottle off to where its close to getting off plain. Thats usually the best speed for MPG.
Silvertip
Install a fuel flow meter and you will know within 500 feet of the dock what the best cruise speed is.
luckyinkentucky
I've seen the Fuel Flow meters, but I can't find one for less than $500! :eek:
I would like to find one as cheap as possible, if you know what I mean. Also, are they easy to install?
dingbat
There are two or three brands that are under $150. The Northstar units is under $100
Silvertip
Google or Yahoo "Northstar 210" or "Navman 2100". They are identical units since Northstar acquired Navman. These units work well. I have one.
steelespike
Like he said a flow meter is the best way.
Best mileage can be from just on plane to about 2,000 rpm above.
depending on setup etc.
dajohnson53
I have a Standard Horizon fuel flow meter that was in that same price range and is very similar/identical to the Navman unit. At the time I bought it, I kind of assumed they were re-badged identical units. I believe they even used the same sending unit.
I'm wondering how your luck has been with the Northstar / Navman unit? Unfortunately, I've had nothing but problems with my SH and am about to abandon it. In fact, I believe SH has discontiued their FF meters. I've had the sender replaced once (defective/cracked original unit), but have had the gauge itself replaced twice and now have the same problem a third time - total fogging and malfunctioning of the display.
Anyway, when it worked, I was happy to have the flow meter and recommend them if they can be reliable. I liked seeing the GPH display, and set it up to use as a fuel remaining gauge also, and it was VERY accurate.
But, in order to determine the most efficient speed across the water you need to calculage MPG which involves the flow meter and an accurate speedometer (i.e. GPS) and then calculate maximum MPG. I found that my maximum MPG wasn't the same RPMs as maximum GPH. I could go further at a higher GPH because I was going faster. Maximizing distance/gallon was my goal.
There are GPS units that hook in with flow meters to calculate MPG on the fly.
Silvertip
My Navman also experienced a transducer failure but apparently a piece of debris passed through it as the vanes on the impeller were broken. I installed an automotive fuel filter ahead of the transducer and the new one has been flawless. No issues with the head unit.
haskindm
The absolut best RPM for the absolute best gas mileage on ANY boat is.........0 RPM. Of course you will need a strong wind or someone to tow you to get anywhere. That said, it will depend on your boat, the sea conditions, and how your boat is loaded. The fuel meter is the best advice. I hope Santa brings me one for Christmas. Are you listening Santa? ;)
