Clack Clack Clack Clack Bang; What Just Happened
Outrage 19
I don?t know
Can you get it started again
I?ll try??..No its locked up
Oh look there?s water coming from under the hood
That?s not good
Any One Need Spare Parts from an 82 Evinrude 140
Outrage-19
Re: Clack Clack Clack Clack Bang; What Just Happened
It's been so long since I logged in I forgot which log in I use
SnappingTurtle
That looks rather nasty! :eek:
Maybe some "Sea Foam" would help. :confused:
Sorry to see that happen to you. :(
tashasdaddy
you killed that one, looks like a salt water motor.
dimock44
JB weld for sure
Xcusme
???...What's the big deal? It looks like the rectifier bolts came undone...just tighten them down and you should be good to go....geez...
Outrage 19
You know the old saying 2 out of 3 anit bad. IT DON'T APPLY TO OUTBOARDS. Before I put the motor on I checked compression (all good at between 118 and 120), spark (nice blue crisp and hot). But I didn't pull the carbs and clean them. She fired up nice and easy on the hose. Ran her for 1/2 an hour pulled one plug wire at a time to make sure she was making power on all 4 cylinders. So off the the river we go. Pulled away from the ramp and Clack Clack Clack Clack Bang; What Just Happened.
22ISLANDER
A severe case of engine self ventilation.
Major bummer.
seasprite
looking at the rust on that rod I would say water intrusion & I can't see any oil on it ether. sorry to see your motor go like that.
ftltony
it would appear to me that after reviewing the photos that it was definately the Flux Capacitor.
jay_merrill
Hmmmmmmmmmm .... well ........ you will certainly be getting more airflow, so I think you should adjust the mixture for LOTS more fuel!
iwombat
Dayum! Whatcha going to do?
PM me if you need a rebuildable block - I may have something.
Benny1963
looks like the rectifyer fell off ,
i also have rebuidleable block
F_R
In the midst of all the funn'in, I'd guess water intrusion that rusted the roller bearings, and when you started it up rusty rollers don't. But I don't know that for a fact without more inspection. Dead is dead.
mikesea
Balance is important,an EASY fix would be to pull the top pistons out ,and make a 2 cyl.out of it.I realize you probably have 3 perfect cylinders,BUT,balance,you NEED balance.Uh Oh,better get Maaco.
triumphrick
Hmmmmmmm.......heard of lettin the dog out, but not the rod out. :eek:
CATransplant
It's dead, Jim. I told you you canna get any more out of the engines, but you had to go to Warp 6. Now we need all new dilithium crystals. :confused:
jimmbo
Nothing a little paper mache and water color won't fix up
Outrage 19
Hay everyone don?t feel too bad for me. The motor cost me $50 and a week end to put it on.
I?ll put the 90, that was originally on, back on this week end and be back running by Sat. afternoon.
Oh and BTW, for those who like to figure out why, what looks like rust on the connecting rod isn?t. Somehow the camera flash made it look that way. If you shine a flashlight in the hole everything looks nice and shiny, except of course the score marks on the #1 cylinder walls.
Outrage 19
For those interested I installed the 90 two weeks ago and finally got the chance to make a test run yesterday. It worked fine. Now lets all go Fishing, Tubing, Water Skiing, Knee Boarding, Cruising, and above all have a good time.
