I'm thinking of buying..50hp Tohatus
ifishinwater
Questions....I have a 1965 15ft Starcraft..Is the 50hp Tohatus weight (205 lbs) to much & how you think it will handle on the Starcraft. Right now I have 1966 40hp Evinrude with CMC tilt & trim on boat runs great just wanted more power & newer remote. How is the sound level on the 50hp & what kind of milage are you guys getting out your 50hp. Any other information I wecome.
PS: What is a fair price to pay for motor & controls...the 66 is for sale & the CMC tilt / trim if I get the 50hp
TOHATSU GURU
Re: I'm thinking of buying..50hp Tohatus
I think it's too much for the boat, but that's just an opinion. Sound level and mileage vary depending on RPM but in general, it's as quite as a 4-stroke at mid range, a little louder at an idle and you wouldn't be able to tell the difference at WOT. Fuel consumption is better than any four-stroke up to mid range and then becomes the same at WOT.
ifishinwater
Do you think the 40hp would be better..they are the same weight.
I understand one can detune the 40hp & make it a 50hp. What do I lose if that was done?
Thank you for your reply.
TOHATSU GURU
It's the hull I would be worried about rather than the engine itself...The 50 and 40 have a different ECM and it would run over $1000.00 to convert one to a different hp.
ifishinwater
The hull is aluminum & stern has been rebuilt. The dealer gave me price total$48000 for complete installed & the 40 detune would be $200 less. I think that a good price...what you think... what does ECM stand for & what could happen to the hull....I'm thinking the 50hp as $200 is not much more. I boat on the Missouri River & going up river might have need for a bit more hp & won't have to open up all the way.
Thanks for your imput
TOHATSU GURU
The price is really low and I would jump on it. ECM stands for electronic control module which is the puter that runs the engine. I think that a hull that old needs to be looked at very carefully by the dealer to determine if it can stand the pressure put on it by the engine.
ifishinwater
:) I'll will jump on it & have the dealer check out the hull.
I went my a local boat repair shop & their people said boat could handl motor & said was a good price.:)
good to know it's a deal...and the factory may have a rebate..checking it out
Thanks
ifishinwater
Well I did not get a Tohatus ...I go a 75hp 2008 Honda never been in water it needs a bit of work The reports on the new 2008 fule injections said to be good..parts are in hope to have running & 2006 Polor Karft 165SC fixed & in the water by Saturday :) Sunday.
The missouri river just came about 19ft, that might stop the river trip.:( :DThanks for all your imput GUYS!!!!
Michael
