hello all,
i have a 98 mercruiser 5.0 w/ alpha drive. i have been chasing an overheating problem for 2 seasons now. it will run at around 200 degrees at idle and 225 when at slow speeds. the temp gauge will dance eratically from time to time. once i try to start moving i will run upwards of 225+ and will get an overheat alarm. I have so far changed the impeller, water pump, risers, and mainfolds. my marina mechanic is running out of ideas as am i .
i am thinking that i can rule out a faulty gauge/reading b/c the temp gauge and alarm run off 2 different sensors so if they are both showing a problem, then there most likely really is one.
one thing i noticed is that the small hoses from the tstat housing to the risers feels kinda "crunchy" i am wondering if that is normal or could it be setiment or salt deposits restricting water flow?
there was a thread chronicling the same issue i have but he stpped posting after finding a snapped impeller shaft. my mechanic just did my impeller last season as a part of this problem so i can only assume that he would have noticed a shaft issue?
has anyone come across an issue like this?
thanks,
John Geldert
long island, NY
thanks,
John Geldert
long island, NY
