Hello,
I have a 1983 Mercury 100HP four cylinder. I had the constant beep problem and wound up buying a new electronic module and that fixed it, or did it. The motor runs fine until you shut it off (after it's warm). It's like someone disconnected the battery. No power, motor won't turn over, can't here the choke click when you push the key in, power tilt doesn't work. Like I said, it's like someone disconnected my battery. Some times I will here one anemic little half hearted beep like some one is choking the beeper but thats all and it runs just fine till I turn it off. Most of the time it will work again after it cools down but one time it didn't. I jumped the silenoid, disconnected and reconnected the module wire and it turned over and fired up again (didn't do anything in my opinion that should have fixed anything so I think it may be temperature related). Any Ideas on what could be causing the problem?
Thanks
Thanks
