Johnson 4hp power pack
rythmman
I have a 4hp Johnson J4RESR. What is the correct distance between power pack and flywheel?
rythmman
Re: Johnson 4hp power pack
Close enough not to touch the magnet seems to work.
cr2k
If this is the one with the posts cast in to the plate you should have them flush with the cut back part of the post. Used to be you put a band on there and moved them to contact the band, which made them flush with the posts.
