Re: smoker. porpoise
Cloumar:
The screws are pretty large. On my 19 foot Osprey, the top row of screws caught part of the wood sandwiched in between the aluminum transom panels, so no issues there. The bottom row went right into the bilge. I used generous amounts of marine sealant on every screw. Also, the metal screws are so large that I had to use my big Sears 24 volt cordless drill to get them tight. I can't see how they could come loose, but I inspect them after every outing.
In the eventuality that the screws do come loose, I plan to remove the trim tabs, have the screw holes welded up, and have brackets welded to the transom to which I can attach the trim tabs.
