Re: 1990 40 hp johnson will idle but not rev up
"cutting out" but not dying...sounds like she's running on one cylinder.
spark plugs, are they wet or dry afterwards? are they the same or different?
fuel line holding pressure?
fresh fuel?
water or debris in the tank?
fuel tank vented?
first, compression test, should get about the same reading on both cylinders, within 7% or so.
second, spark test, should jump a 7/16" gap on an inline tester.
time since last carb rebuild?
