1970 115hp Evinrude outboard won't start at key
artshawna
We recently purchased this and when we first got it, the motor would start only sometimes from the key. We took it out a couple of times like this and dealt with the fact that we would have to resort to jump starting at the solenoid. We have replaced the ignition switch. Still, it would only start at the key when it felt like it. It is now to the point where it will not start at all from the key, only by jump starting it. We bought a new starter and still the same problem. The battery is always fully charged and when you turn the key, there is not even an attempt to turn the boat over. Acts as if there is no power at all. I know we are getting power because when you turn the key half way, our fish finder beeps. Any suggestions would be great.
iwombat
Re: 1970 115hp Evinrude outboard won't start at key
disconnect the connections at the solenoid and the switch and clean them. Might also want to do a continuity check on the ignition wires from key switch to engine.
You have a broken wire, or dirty contact.
TommyA
If you have some help you can take the small wire loose from the solenoid and put a multimeter on it. Have another person turn the start key to start. You should get battery voltage at the wire end. If not then there is a problem with the wire between the switch and the solenoid. If it checks correctly then its the connections
nguoi_viet41
you may have problem with solenoids
http://forums.iboats.com/showthread.php?t=158071
F_R
Check the safety switch!! Know what it needs before buying parts.
patrick4266
I had the same problem and it turned out to be as simple as adjusting the nuteral safty switch.
iwombat
Good call on the neutral safety switch.
artshawna
OK. I am going to relay all of these options to my husband when I get home from work. Just to be clear, is the neutral safety adjustment inside the casing where the ignition switch is attached? Thanks for all the help.
iwombat
Yes it's inside the remote console.
TommyA
I would think that if it is the neutral safety switch then a wiggle of the throttle handle might get a start results. Just might!:)
mfg boat man
sorry to bother u guys....can ne one tell me how to post on here...im having sometrouble with my 1970 115 and always been able to find my problem in someone elses post...but not this time...id like to post exactly what is goimng on....everyone is so helpful here...please let me know...it would be greatly appreciated...
Dan
ezeke
No bother. Go back to the first forum page with the list of threads; the "CREATE NEW POST" flag is in the upper left side under the Johnson Parts link.
If you set your User CP, responses to your thread will be emailed to you.
