no fire from coil
lquested
just bought a new to me boat i had a bayliner w/ out board.. now i bought a 1985 celebrity calais 18' w/inboard.. dont know anything bout this motor it says on the valve cover model# mcm190...displacement:224cid...serial #a365629.. on the stern drive it has mercruiser 190hp..any info would be helpful about this motor..(4cyl).. problem is no fire from coil i took test light and with ingnition on i have power from the + and - on the coil.. im guessing the points and condensor are bad. no spark there either.. although my son turned the ignition on while i was turning the screw on the points and i felt a good jolt.. am i right or could it be something else?
thanks
lee
jerryjerry05
Re: no fire from coil
Your diagnosis sounds good.Replace points and cond. Jerry
chiefalen
First things first.
1-Get a factory manual year specific. Seloc second best-claymor garbage.
2-Compression check all the cyl. plugs out anyway.
3-Do a full tune up via the manual. Points, plugs, set dwell, timing, check them wires real good, older boat.
3-Check the battery cables, they good? Clean all the connections, grounds also.
4-The starter wires clean them good too.
When you go to start it, if it were my boat i would use a external tank, and clean all the filters. One at the fitting to the carb, in the fuel pump. And water seperator if you have one.
post what happens if a problem we will help you, better minds here than mine
lquested
ok wife picked up points and cond. i got home and put em in and the motor fired up took to lake for an hour and it ran like a champ.. the guy i bought it from said it needed another carb .lol the whole time it was the point and cond going bad on him...cant wait to spend the day on the lake...:cool:
i was on the lake with my kids checking out the boat for the first time and i guess i had the bow trim way up when i slowed down the bow went straight up:eek: and scared the daylights out of us. one son thought we was filling up with water my other son looked in the motor compartment no water . i hit wot got to plane (very quick) pushed bow down then slowed down worked fine....hahaha now i know how to scare people that go with me in the boat..:D cant wait for that either....
