'89 V135 Low RPM
Webenew
'89 Searay 180 with V135 s/n c166937. Max RPM is 3500 and will intermittently jump up to 5600 at WOT while cutting in and out. I?ve eliminated stator, switch boxes and coils as possible cause and trigger checks good. Also replaced fuel pump, filter & lines and cleaned carburetors and installed new gaskets/needles & seats. Good spark on all cylinders. Looking for hints on what non-typical failure might be causing this problem. Thanks in advance.
Laddies
Banned
Re: '89 V135 Low RPM
Have you checked the switch box bias circurt and the rectifier? Also a bad high speed winding in the stator will act that way and have good spark at idle and mid range, how have you tested the system with a DVA, because a OHM meter means nothing with the type of problem your having.
Webenew
Bias circuit & rectifer good. I found all cylinders have good spark at idle but #3 & #5 have drop out at partial throttle. DVA checks of stator look good. Thanks in advance!
Webenew
Correction...#3 & #6 (not #5) drop out at partial throttle.
Thanks
Laddies
Banned
In as much as 3&6 have no common part in the ign system you need to check for a voltage spike in both the ign system and the charging system while running the engine, it should show just before or at the time the miss occurs. It could be something as simple as a bad connection, it doesn't have to be a bad component.
Webenew
Since the problem was related to throttle movement I checked the trigger first. I disconnected wires from the switch boxes and all ohm readings were good. I checked each wire to ground and found intermittent continuity when I advanced the throttle. I couldn't determine where the short was located. I adjusted the trigger harness by moving the harness clamp and found I could eliminate the short. I'll replace the trigger at a later date but but for now its running great...it's usually something simple, huh?
Thanks!
j_martin
Correction, 3 and 6 share a trigger coil.
Check the trigger harness for damage where it comes out from under the flywheel. A neat splice and adhesive lined heat shrink will fix it.
Been there, done that.
hope it helps
John
sschefer
Just thought this might show where to look for a short. The trigger wire cover can wear through or melt as this one has.
