OhWellcraft
Thread starter- Joined
- Jun 22, 2007
- 277
2005 larson 350 mag mpi bravo three drive. Took to the lake 3 weeks ago starts on trailer in water, idle out of nw zone drop hammer goes few hundred yds dies have to get towed in. Mechanic looks over everything replaces plugs,wires, dist cap, oil&filter, F/W seperator and informs me there is alot of water in the seperator. Drain tank of all fuel, new seperator, start on muffs run for 15-20 min runs fine. Take to lake yesterday starts on trailer in the water back off trailer idle over to docks 200 yards away dies wont start back up. pull F/W seperator water in it, have son turn key a few times on and off to pump into cup looks to be about 30 % water in gas? Also looks like new oil is milky only has about 25 minutes run time. While running on muffs looked over entire engine no leaks/ didn't get hot. I'm at a loss what should my next step be? Thanks for any help anyone could give.
PS ran fine last time out last year took on a bit of water mechanic fixed speedo hose that was leaking, then winterized.
