Hermyboy3000
Thread starter- Joined
- Jul 25, 2005
- 93
I can't get any spark. I've just installed new Pertronix Electronic Ignition, new coil, 1 year old rotor, 2 yr old spark plug cables, older distro cap (but in good shape, no cracks, no carbon, the posts are bright and clean).
Here is the story, my boat was running great 2 weeks ago, then by the end of the day it started to bog down then it died. I originally thought it was my Hot Spark ignition module, but then I tried reinstalling my points and condenser and I still couldn't get it started. So I we to paddle home.
My new coil that I installed today checks as good, my old one is good too (I think).
I have checked my voltage at the ignition switch, I have 12.3v when I turn the switch, I have 12.3v at the + side of the coil. When I try to start the motor the voltage at the + side of the coil drops to 10.1v (not sure if this is what's supposed to happen?).
When I pull the high tension cable of the distro cap and ground it the engine block I get a weak orange zap. This is where the problem may reside, but I'm not knowledgeable enough to diagnose the problem.
I have attached a spark plug tester to each of my plugs and I get NO spark at all.
Here are some of the specs
AQ130
New Battery (12.3v)
Solex carbs are rebuilt and working fine
fuel system is good
All was running great until I switched to EI, now even if I switch back to points I get nothin'!
AQ130
New Battery (12.3v)
fuel system is good
