jeremy5780
- May 8, 2008
- 147
I have a 1998 115 i rebuilt had it bored 20 over all 4 cylinders. Put it back together and it fired up but runs like crap it coughs and wants to stall out in idle. So i rebuilt carbs and they are like new!!! I did a link and sync, and it stoped the coughing due to the top butterflys being just a hair open. Now it idles fine but if you rev it up real fast then drop it back to idle it stalls out. It will start right back up and start coughing and wanting to stall again.So i read the manual and tried to set the timing pointer, and it is way off. I follwed the book word for word and cant get the pointer anywhere near the mark on the flywheel! So I decided to forget this and move on next i did a cam follower pickup sync. Now the only way the motor will start is with the timer base advanced forward all the way. It starts and idles with the timer base as far forward as it will go (its the only way the motor will start) so the book states to hook up a timing light to the #1 wire, and with it idling the timing pointer should be lined up within 3 to 5 degrees BTDC. It dont, i would say the fly wheel mark is atleast 2 inches before the timing pointer with the timing gun on it. And if i try to push the timing base back the line on the flywheel starts to come closer to the timing pointer, but the motor starts spitting and sputtering and stalls! and i have a hell of a time starting it.
