fireranger40
- Jun 25, 2008
- 15
When i first purchased this engine, I knew it needed a new power pack. After replacing it, the engine started but ran pretty rough and it would die. After further testing, I noticed the magnets were loose on the flywheel. I replaced the magnets, installed them according to specs and verified the flywheel sensor alignment (ok). I now have no spark again. The stator checks ok although I am not getting anything on the brown/brown white wire coming from the stator (not normally part of the troubleshooting). Rectifier checks ok too.
Any chance running the engine with a new power pack and loose flywheel magnets might have messed-up my new power pack????
Is there any diagnostic to test the powerpack by itself to make sure its good?? Powerpack IS getting power and yellow/red wire is good too.
I also checked for any possible "kill switch" and/or grounding condition and everything seems to be in working order. All wires seem to be healthy and in good condition.
Engine is spinning freely and faster than 300rpms.
I also disconnected the wire harness and jump started the engine using the starter and did not get any spark either.
Thank you for your help! This is week three trying to get this baby to come to life!
