I am stumped i have a 1985 johnson vro v4 90 hp. it idles great but misses when its in the water and you just putzing along you really notice it. but it runs like a raped ape at full throttle plenty of power. coils new, power supplies new ,carbs cleaned throughly, timing good, after running plugs are wet no dry. also if i spray choke cleaner around the base of either carb it trys to stall , also at the lower base of intake manifold. so i assumed that that since it was so close to the base that it was sucking it thru the crank seal. but whaen i took the power head off all i found is that the exhaust gasket was corrupted and had been leaking have new gasket set on the way with new crank seal. also motor starts great at the flick of the key and has 125 psi compression in all 4 cyl. vro is disconnected and plud the oil line. please help sorry so long any help would be great.
