WOT in idle (solved)
KenStone
A couple of weeks ago I had a problem with WOT in idle, as i explored the problem I finally found a bolt stuck in the carb. I removed it and started the boat to find that I still had the problem. So I then noticed that the carb flangs on 3 of the 4 carbs where slightly open so i readjusted the carb sync bar and started the engine.... And with that a smooth loping idle.....
