Mercruiser 5.0 wont start - fuel problem?
viperdogg
My 5.0 EFI was running great. I shut down for 2 minutes but it would not restart. I tried advancing the throttle during engine turnover and fuel started pooling under the spark arrestor. I cleaned that up and checked the ignition which is fine (getting spark to the plugs). Seems that something is wrong with fuel supply to the carb. Any suggestions on things to check?
thanks, Viperdogg
Fishermark
Re: Mercruiser 5.0 wont start - fuel problem?
My 5.0 EFI was running great. ....Seems that something is wrong with fuel supply to the carb.
Not to be picky, but you either have a carb or EFI - not both. You will also need to give a little more information than a Mercruiser 5.0 liter. Year? Etc. Most of the pros will ask for the serial number, so you might as well dig that out as well. ;)
Welcome to the forum!
SeaRay Dan
Last time my 260 HP with Carb did that it , the float in the carb was stuck,
viperdogg
definitely an EFI. its a 2002 model 5.0. I managed to get it running again After i cranked it one time with the throttle a little open. Seems like it was not getting any air but opening the throttle moved the throat valves a little open. So, what could be the problem with the EFI if it is not allowing air to get mixed in the chambers?
