reelfishin
Thread starter- Joined
- Mar 19, 2007
- 3,050
I got to messing around with a buddies boat the other day. It's a mint clean 16', '89 Bayliner Capri with a Force 70hp outboard. The boat is immaculate and has been garage kept since new. It probably don't have more than a few hundred hours of use on it. I drove it the other day after he complained that it was a real workout to drive. He said the steering was tighter to one side than the other. Not noticing a problem at rest, I took it out on the river to see.
It has a severe pull to the left as soon as you put it in gear. When in gear, even at idle, the wheel begins to steer left. At any sort of speed, you are fighting it constantly. Over 20 mph, it takes all your strength to go straight and right turns are a real chore.
I checked the steering cable, steering gear, and motor but found nothing out of the ordinary. The steering is rotary style, looks to be a Teleflex unit, the motor has a hydrofoil on it, he said the marina added that to gain a place to add tabs to counter the torque steer. They have them at full angle to correct the steering problem. I tried several positions, left and right, where they had them is the best option. I tried it with the foil off, it's twice as bad. The motor steers normal, there's minimal tension without slop in the pivot pin and the motor is mounted dead center and perfectly straight. There are no bent fins or skeg and the prop is what ever it came with new. He said he's gone round and round with it since new and nothing has ever helped.
The amount of steering torque is extreme. The minute you put this in gear, even at near zero speed, the wheel is pulling left. I took it up to about 35 mph, and at that speed, I didn't feel safe since it took both hands to keep the boat straight and a right turn was often a losing proposition. The wheel would slip back as you hand over handed to the right. I found myself doing wide left circles to go right. If you let off the wheel or relax a bit, the motor goes full lock to the left.
I though maybe something strange with the prop, but it looks fine to me, nothing bent or oddly cupped.
Trimming the motor down makes the problem worse, with the motor up, the problem is less but still bad. The motor is set with the anti cavitation plate about 1/2" above the bottom of the boat. One marine mechanic mentioned that if the prop was uncovered in the water it could create a serious pull, but the prop is well submerged and it does do it from the minute you put it in gear.
Any ideas?
Any ideas?
