John Lapic
- Sep 8, 2007
- 57
I have a 1971 Johnson 9.5. It idles fine and is smooth at slow speeds. At WOT it seems I am only at about 3/4 speed or RPM. It does not bog down, just won't open up. I ran it for several minutes at WOT, and at one point it took off, only to stall shortly after. I had trouble restarting and noted a loss of pressure in the fuel line bulb. I pumped up the fuel line with the bulb and it started fine, just no power again at WOT. Any suggestions?
Also, I am about an hour to the nearest water. Can I open up the throttle in a barrel? I have a 40 gallon drum that I can use, but have heard it is not good to run it much above idle. Something about running away. I am a novice here so any help is appreciated
