1957 johnson
abba gale
I have a javlin 35 hp Johnson one of the spark plugs were striped out so I replaced it with another cylinder head that I have on another motor . Both motors are same year the one I replaced it with is a evinrude. Will changing this cause a loss of power ?? I cleaned carb, replaced coil and points rebuilt fuel pump . it is a single line type. it idles pretty good but no top in very boggy will not plane out. Please help..
wbeaton
Re: 1957 johnson
Evinrude of the same year shares the same cylinder head so no worries.
abba gale
Re: 1957 johnson
What if the packing around the jets are in bad condition will that also cause no power ? thanks...
abba gale
Re: 1957 johnson
what if packing around the jets are in bad condition will that cause this power loss......thanks...........
wbeaton
Re: 1957 johnson
If the packing around the jets is in bad condition then you didn't clean the carb properly. Revisit your carb. Recheck your ignition.
Loss of power could be a few things. How about some more detail after you finish checking the carb and ignition.
F_R
Re: 1957 johnson
Right, check compression and spark. You are running on one cylinder. Figure out why by doing those tests. The carburetor feeds both cylinders, so that is not the problem.
